16761 Diskussionen
Help with Heatsink Installation E97381-001 for the I7-970 (LGA 1366)
Mitarbeiter
3.885Aufrufe
I'm installing this Heat-Sink which I purchased when I worked with a national retailer as part of the Intel Edge program. The small manual which claims to be ''installation instructions" provides absolutely no instructions for the heat-sink installation. Although it's somewhat self-explanatory, I'm looking for guidance on which direction the fan on the front (or rear) of the heat-sink is supposed to point when the heat-sink is installed. Does it make a difference?
The miniscule manual refers me to the following address http://www.intel.com/go/integration http://www.intel.com/go/integration which then tells me I have to register as a technology provider which I am no longer. There is no english language guidance in the manual regarding the heat-sink installation, just pictures which do little to point me in a particular direction for the positioning of the fan.
Any help is extremely appreciated.
2 Antworten
Adolfo_S_Intel2
Mitarbeiter
2.429Aufrufe
The integration manuals that we have are the ones located at:
http://www.intel.com/support/processors/corei7/sb/CS-030866.htm http://www.intel.com/support/processors/corei7/sb/CS-030866.htm
But I believe that is the same one that you have in printed version.
Regarding the fan, it does not matter the side that you install it.
Mitarbeiter
2.429Aufrufe
Thanks for your reply Adolfo!!
Antworten
