17147 Discussions
Help with graphic drivers
M1dje
Hello
i have a monoblock msi on intel gold G6405 processor
can't find graphic drivers for this video card
video card is UHD Gpraphics 610
thanks for response
n_scott_pearson
Comet Lake processors are covered by this driver: https://www.intel.com/content/www/us/en/download/776137/intel-7th-10th-gen-processor-graphics-windows.html.
Hope this helps,
Catulpos_Intel
Hello M1dje,
Thank you for contacting Intel Customer Support.
You can access this link: Intel® 7th-10th Gen Processor Graphics - Windows* for Intel generic driver but for better compatibility of your device, you can also download the drivers from your board manufacturer. Thus, to assist you effectively and provide you with an accurate recommendation, please provide the exact model of your MSI motherboard.
Thank you and have a nice day.
M1dje
Thanks everybody for response
But
I dont' have á positive result, because when i started installer its finished with error code 8 - There is no device compataible with this driver
both links are similiar
@Catulpos_Intel
driver for motheboard i cant find on vendor web site, model of MSI motherboard is  MS AE031
thanks
n_scott_pearson
You may need to use a Clean Install processor. Here is mine:
  1. Download - but do not install just yet - the referenced driver package to your PC.
  2. Disconnect system from Internet. Unplug Ethernet cable and/or disable Wireless. Note: if using Wireless, it should be disabled in such a way that reboots can occur without it automatically re-enabling.
  3. In the Apps and Features applet, check to see if there is an Intel HD Graphics or Intel Graphics entry. If not, skip to Step 6.
  4. Click on the Intel HD Graphics or Intel Graphics entry and select Uninstall.
  5. Reboot the system, keeping Internet access disconnected.
  6. From Device Manager, check if there is an entry for an Intel Graphics adapter. If you see only the Microsoft Basic Display Adapter, skip to Step 9.
  7. Right-click on the entry for the Intel Graphics adapter and select Uninstall Device. Checkmark Delete the driver software for this device and then click on the Uninstall button.
  8. Go back to step 5.
  9. Install the new driver package that you downloaded in Step 1.
  10. Reboot the system.
  11. Reconnect Internet access.
  12. Test.
Depending upon the history of your Windows + Drivers installation, it may take multiple uninstall (and reboot) cycles to clean out the old installations, so don't give up on the process. If you get to, say, 10 cycles, stop there and attempt the installation of the downloaded driver package.
Hope this helps,
Catulpos_Intel
Hello M1dje,
We are sorry to hear that you experienced some issues with regards to the installation of our graphics driver.
For us to effectively assist you, please provide the following information:
We look forward to your response.
Catulpos_Intel
Catulpos_Intel
Hello M1dje,
I just wanted to check if you saw the information posted previously and if you need more time to provide the information requested?
Catulpos_Intel
Catulpos_Intel
Hello M1dje,
I hope this finds you well.
Thank you and have a nice day!
Catulpos_Intel
