16814 Discussions
How can I get the IO Margin Tool for i5-8400
Elon_z
I want to download the IOMT tool for i5-8400. But I can't search the tool location.
Earl_Intel
Hi Elon_z,
To better assists you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • May I know where will you use it for?
  • What is the make and model of your motherboard?
  • What BIOS version do you currently have on your system?
  • Can you describe the issue more to us?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Elon_z
Hi Earl E,
Thank you for your reply.
I want to use IOMT to measure SATA port signal for SSD.But I don't have this tool.I have collected the system information with the tool you provided.
BRs,
Elon_z
Earl_Intel
Hi Elon_z,
Earl E.
Earl_Intel
Hi Elon_z,
Thank you for your response, no worries, I will further check on this and provide an update on this thread as soon as possible.
Earl E.
techgorilla
Thank you for your patience. You need privileged RDC access. The information related to this tool can be found in there: https://www.intel.com/content/www/us/en/search.html?ws=idsa-default#q=Intel%C2%AE%20IO%20Margin%20Tool%20for%20Eagle%20Stream&sort=relevancy&f:@tabfilter=[Developers]
Earl_Intel
Hi Elon_z,
Its best to contact RDC. Additionally, you can also check our article on 'How to Download the Intel® IO Margin Tool (Intel® IOMT) Mask Installer for Intel® Xeon® Scalable Processors' as a reference for contacting RDC, as the steps are the same for Intel Core processors.
Earl E.
Elon_z
Hi Earl E,
OK. Thank you for your help!
BRs,
Elon_z
