16774 Discussions
How measure correctly power Package on processor with FIVR?
Dear Intel.
When i compare MSR_PKG_POWER_INFO my 5820K with 8700K.i was amazed power consumation my CPU.
It consume less than new Coffe Lake-S on the testimony RAPL registers?
When i compute power consumation by measureamen SuperIO using VCCIN voltage and measured current.
These measurements seem to be true(120W vs 67W RAPL Value),
http://ultrapic.net/i/no_category/0/4/3/1635c.png
Hello NX_ECX
Thank you for posting in the Intel® community.
Allow me to share with you that the power consumption readings might change depending on the motherboard design, in this case, I recommend contacting the Original Equipment Manufacturer (OEM) for detail information.
In case you are a designer please see your private inbox. I have sent you a message.
Hope this helps.
Leonardo C.
