Hi all,
I'm trying to port u-boot on my OWN hand-made board.
I think there is a problem related to my SDRAM configuration because when I reset the board the following message even does't apear on the serial console:
Hit any key to stop auto boot: 0 Do you guys think it's really because of SDRAM configuration or not?
If yes,please tell me how can I fix the problem(which files of u-boot tree)?
If no,So from where does this problem originate?
thanks alot
- Tags:
- Memory
Hello metisd,
If this based one of our Intel® Boards or Intel® processor, I would recommend to check our https://www.intel.com/content/www/us/en/embedded/embedded-design-center.html Resources for Embedded and IoT Designers.
Amy C.
Thank you dear Intel corporation staff
But since I'm working on a custom board, the standard board documentations won't work
metisd, in that case try using third-party communities like: http://www.tomshardware.com/ Tom's Hardware: For The Hardcore PC Enthusiast
Amy C.
Topic Options
