16777 Discussions
How to use the turbo boost 2?
BFeli
First, I'm Brazilian, so I'm the translator, so sorry for the words ...
Well, I have a Intel core i5 2300 2.80 GHz, only wanted to upgrade the bios of him, because his is 2011, and I couldn't, I was on the site of the MAI which is the manufacturer of bios, I've been on that is the manufacturer of pcware motherboard, but it the bios I have to install manually by the computer, but I wanted a simple and useful program.
Well, I saw my processor information here at Intel that is 2.80 GHz, and can get to 3.10 GHz, but I wanted to know how, because I can't mess with this turbo boost, someone teaches?
Allan_J_Intel1
I understand you need to update the computer BIOS. At this stage, you need to contact your computer manufacturer's web site and download an appropriate BIOS version for your motherboard model or computer model.
If you managed to update the BIOS, you need to make sure the BIOS provides an option for Turbo Boost and enable this feature that way you can get up to 3.1GHz of processor frequency.
Allan.
BFeli
There's the bios rom file, but I don't know how to update the bios, I have the pendrive and portals, but the problem is I don't know.
Allan_J_Intel1
If you need assistance installing the computer BIOS. I recommend checking with your motherboard or computer manufacturer. If you own MSI motherboard try this link for support: http://br.msi.com/support MSI Computer do Brasil - Notebooks, All-in-One, Placa-Mãe, Placa de Vídeo e muito mais
Allan.
BFeli
Do I have a IPMH61R1 motherboard
Do you need an MS-DOS disk, can I replace it with a flash drive with boot?
Allan_J_Intel1
I am not familiar with the process to update BIOS on IPMH61R1, I recommend checking instructions linked below:
http://www.pcwarebr.com.br/produtos_mb_ipmh61r1.php?id=4 PCWARE
Or contact your motherboard maker for more information: http://www.pcwarebr.com.br/contato.php PCWARE
Allan.
BFeli
I was wrong, the motherboard is IPMH61R3, and there is the tutorial of how to upgrade, but I don't understand, I've already contacted them, but so far nothing ...
I didn't get that part of the image http://prntscr.com/7nlsw8 http://prntscr.com/7nlsw8
Allan_J_Intel1
zGotz, Contact your computer or motherboard maker for information about how to update the BIOS.
Allan.
