I/O issues?
I've just completed my first build and I'm having some very odd problems.
Components (all new):
CPU: Intel i7-2600
Mobo: MSI P67A-GD53 (B3)
GFX: XFX Radeon HD 6870
16Gb Crucial Ballistix memory
Intel 520 SSD (128Gb)
WD 2TB Hard drive
LG Blue-ray drive + Sony OptiArc DVD Drive
I've been having real trouble reading DVDs - on either of my new drives, and on a variety of media. This includes Windows and Ubuntu install disks, so the problem occurs before an OS has been loaded. I even had the same troubles on an external USB drive.
The Windows install would BSOD, the ubuntu drive complains of I/O issues.
At one point I managed to install Windows 7 from a USB stick, but had similar issues installing software. For example, The MS Office 'default install' managed to work, but there was a consistent problem reading a file during the 'custom install' - it would complain of disc read issues, and stop.
I've just now finished trying a bootable Ubuntu USB stick - I couldn't install from this (I/O issues), and the 'try without installing' feature set up an OS, but it was very instable ('disk errors').
I've tried 3 different DVD drives now, 2 internal and one external. I've tried my SSD, and HDD alternately. I've tried various RAM configurations, and 2 days of Memtest on the RAM succeeded without errors. I've tried all the BIOS settings available (very few), and tried updating / downgrading the motherboard firmware. With Windows installed, I tried various driver updates.
I convinced myself it was a problem with the motherboard, and so RMA-ed it, but the replacement has exactly the same issues.
By process of elimination, I guess the problem must be with the processor, but I don't understand why. Does this sound reasonable - has anyone seen anything like this before, or can anyone imagine what the problem might be?
Or can anyone suggest some tests I can run to show that the processor really is at fault before I ask for a replacement?
Adolfo_S_Intel2
I have seen this issue before, but not related to a processor, it is very uncommon for a processor to fail this way, since a processor either works or it does not work.
At this point I would suggest running the Intel processor diagnostic tool to determine if there is an issue with the processor:
http://www.intel.com/support/processors/sb/CS-031726.htm http://www.intel.com/support/processors/sb/CS-031726.htm
Also you can run the Intel processor identification utility to determine if the processor is being properly recognized:
http://www.intel.com/support/processors/tools/piu/ http://www.intel.com/support/processors/tools/piu/
If the issue follows the processor, the please contact your local support center at:
http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
Or start a chat session at:
http://www.intel.com/support/feedback.htm?group=processor# processor http://www.intel.com/support/feedback.htm?group=processor# processor
Thanks Adolfo, that's really helpful. I'll have a go at these tools this evening and let you know how I get on. Like you, I don't really think it's the processor, but having tested every other component, and had the motherboard replaced, it's really the last thing left to test.
