16761 Discussions
I have an i3-3110M on my Toshiba Satellite C50-A-1DV and I was wondering if I could upgrade to a i7 2720QM???
EAnde11
Henry_A_Intel1
Hello CyberWarrior010
You are requesting if you could upgrade your Toshiba Satellite C50-A-1DV, that currently has a i3-3110M and you will like to upgrade to an i7-2720QM.
Both CPU have uses the same Socket, which is a rPGA 988A / B / Socket G1 / G2, but the problem is that the i7 Max TDP is 45 W and the i3 is 35W. And the most important will be the Lithography which is on the i7 32nm and on the i3 22 nm.
https://www.game-debate.com/cpu/index.php?pid=1284&pid2=644&compare=core-i3-3120m-2-5ghz-vs-core-i7-2720qm-4-core-2-2ghz https://www.game-debate.com/cpu/index.php?pid=1284&pid2=644&compare=core-i3-3120m-2-5ghz-vs-core-i7-2720qm-4-core-2-2ghz
Best recommendation will be to check with Toshiba if your motherboard is able to handel the increase on power usage and that you have enough space for the CPU.
Henry_A_Intel1
