16783 Discussions
I have issue with updating chipset driver using "intel driver update Utility".
GWang23
Hi, I have issue with updating chipset driver using "intel driver update Utility". I downloaded utility and have it scanned my computer. It tells me my Intel chipset Device Software (INF Update Utility-EXE Only) is outdated. Installed Version is 10.0.10586 and Latest Version is 10.1.1.14. Which I downloaded and ran the update, but it just end with failure msg. I have i7 720. Is there certain steps I have to take or it is not compatible with my i7???
If the latest version does not work with my i7, is there another version of software came out after current version on my computer?
Not sure if the msg I get has anything to do with this...but in past few months...not often...but sometime I would get this msg saying something about vendor and device id don't match.
Thanks in advance.
Hello, FlameHawk:
Could please confirm if one of these http://ark.intel.com/products/series/43121/Intel-Core-i7-700-Mobile-Processor-Series%23%40Mobile Intel® Core™ i7-700 Mobile Processor Series is your processor model? What operating system are using?
Amy.
Hello, FlameHawk:
I just wanted to check on your thread; were you able to track this down? If not, please reply with the information requested above.
Amy.
GWang23
I was told by some one my i7 is just too old not compatible with win 10 64...or I guess today's hard/software need....I guess there is no newer dirver update software for my i7 then the one that is currently installed? here is copy of system info.
Let me know...
Thanks a million.
George
OS Name Microsoft Windows 10 Home
Version 10.0.10586 Build 10586
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name GFORCE
System Manufacturer ASUSTeK Computer Inc.
System Model N61Jq
System Type x64-based PC
System SKU
Processor Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz, 1600 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. N61Jq.212, 8/17/2010
SMBIOS Version 2.6
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK Computer Inc.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Mobile
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.10586.420"
User Name GFORCE\georg
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 3.93 GB
Available Physical Memory 2.21 GB
Total Virtual Memory 4.12 GB
Available Virtual Memory 2.33 GB
Page File Space 200 MB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Based on your chipset model Windows® 10 is not supported; therefore, the driver will not install. You might try install the driver from https://www.asus.com/Notebooks/N61Jq/HelpDesk_Download/ N61Jq | Notebooks | ASUS Global, but I noticed that Windows® 10 is no on the list for "Driver & Tools".
Amy.
