16857 Discussions
I5-10300H memory support issue
Greden
I bought a MSI laptop that DDR4 8GB "3200MHz" (PC4-25600) built in.
But it's CPU is I5-10030H that supports "DDR4-2933" memory.
In this case, what should I do?
Just using my memory at 2933MHz?
Or... can I make this CPU to support 3200MHz memory?
Or..... "2933" at "memory support" were not meant MHz at first?
n_scott_pearson
Are you asking from a warranty standpoint? You don't have a warranty from Intel so the question is really moot. Your warranty is from MSI, so if they want to overclock the memory bus, so be it. If adding memory, I would match the speed provided by MSI.
Greden
oh or is minimum support DDR4-2666MHz?
n_scott_pearson
AndrewG_Intel
Hello @Greden
We hope that the information provided by the community has been helpful to clarify your concern. Since the thread has been marked as "Solved" we will proceed to close this inquiry now from our end. Communications with community peers may continue, but if you need any additional information from Intel, please submit a new question as this thread will no longer being monitored.
Andrew G.
