Mother asrock pro b760 pro rs
2x8gb 6000mhz kingston
After changing gpu on rtx 3060
I play game +/- 5min then game freeze and crashes. Fps is ok. I did benchamrks temp is ok no artefacts or crashes. Idk what is going on.
Hi @Krokmm,
- Please provide the SSU log report and share it here so I can review your system's configuration.
- What steps were taken to troubleshoot this issue?
- Was the processor purchased less than 30 days ago?
- Is there any sign of physical damage on the processor?
- Did you overclock the processor? Please note that if the system was overclocked, including voltage/frequency beyond the processor supported specifications, your processor voids warranty.
- When did the issue first occur?
- Have you made any software or hardware changes to the system recently?
- Have you noticed any signs of overheating in the system?
Warm regards,
Randy T.
Hi @Krokmm,
Michael L.
Hi @Krokmm,
Since I haven't heard from you, I will proceed with closing this case. Please note that it will no longer be monitored. However, you may submit a new ticket if you need further assistance in the future.
Randy T.
