I5 3450
kiemegsss14
Hi I'm Miguel from Philippines, I'm having a problem about my processor. My Integrated Graphics Driver is constantly crashing while using chrome or any application and I can't even play a single game with this processor. I tried to replace the processor with my old one (Pentium G2030) and it works properly without any problems. I tried to run Intel Processor Diagnostic tool and I got this result,
--- IPDT64 - Revision: 4.1.5.37
--- IPDT64 - Start Time: 8/22/2021 7:49:51 PM
-- Testing
CPU 1 - Genuine Intel - Pass.
CPU 1 - BrandString - Pass.
CPU 1 - Cache - Pass.
CPU 1 - MMXSSE - Pass.
CPU 1 - IMC - Pass.
CPU 1 - Prime Number - Pass.
CPU 1 - Floating Point - Pass.
CPU 1 - Math - Fail.
IPDT64 Failed
--- IPDT64 - End Time: 8/22/2021 7:51:51 PM
FAIL
I tried everything even reinstalling graphics driver but still got the same problem.
Please help me with this problem because I need to use my desktop for my education.
Thanks!
PS. Sorry for my bad english.
n_scott_pearson
You are running on the latest (and likely last) iGFX driver that is available for your board/processor, so there is not relief from that standpoint.
As for the IPDT failure, please reboot your PC and run the test again. If the failure continues, you maybe looking at a failing processor.
Hope this helps,
kiemegsss14
Here's the ssu test I made btw.
n_scott_pearson
Hope this helps,
kiemegsss14
I tried rebooting the pc and run the test again but still getting the same result. I think I need to replace this processor with a new one.
Thanks anyway!!
