16771 Discussões
I7 3770s locked at 3.5 ghz when gaming
Nedelski
Principiante
1.501 Visualizações
I have this issue with my processor being stuck at 3492-3592 when im in a game, ive tried to boost it myself but to no avail, but it goes back to normal when i exit the game, even boosted to 4.3 by itself, any recommendations?
Etiquetas (1)
1 Solução
Senkuchan
Contribuidor valorado II
1.380 Visualizações
5 Respostas
Senkuchan
1.432 Visualizações
What game(s) are you playing and the name of the application you're using to check the frequency?
Nedelski
Principiante
1.424 Visualizações
Mostly cs2 (forgot to mention the temps, mostly 65-72C), but i played some other open world games and a few not so demanding, but it still was stuck at the same speed, unless i close it.
The program is MSI afterburner
Nedelski
Principiante
1.395 Visualizações
Ah, i think i found the issue, in my bios setttings the turbo technology has set the  4 cores (if active fully) automatically clocked at 3.5ghz, is it safe to change such settings and how could i do it?
Senkuchan
1.381 Visualizações
Turbo boost is automatic. The frequency will only increase if its needed. For more information, check this link: https://www.intel.com/content/www/us/en/support/articles/000007359/processors/intel-core-processors.html
Nedelski
Principiante
1.373 Visualizações
Well for a fact it wont increase, as my motherboard automatically set all four on 3.5ghz when doing tasks that require all 4 cores, and 3.9 ghz on 1 core usage, but thanks for the info appreciate it!
Responder
