16800 Discussions
I7 7700K CPU Temperature at 90c+
CDrur
Hello! My CPU Temperature is at 90c+. My CPU Coolers (NZXT x62) liquid Temperature is at 75c. I’m trying to determine if my CPU or CPU cooler is at fault? The system Temperature is normal. Thank you
AlHill
Is the 90+ under sustained heavy load? describe the conditions. Are you running stress tests?
What operating system version and build?
Doc
David_V_Intel
Hello CDrur, Thank you for posting on the Intel ® communities. Please provide me with the information Al.Hill has requested so I can assist you further. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
Hello CDrur, Please contact us if you have any additional questions. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
MMenc
I'm suffering the same problems can someone help me please?
CDrur
Hey! I can’t fully remember how I fixed it but I think I might have reseated the CPU and applied new thermal paste
MMenc
I changed the thermal paste, mother configs are OK, I have an stock cooler, that can be the problem, I will replace it when covid-19 quarantine ends. Thank you for your high speed answer
