17151 Discussions
I7 Extreme Edition Processors Ram Compatibility
CStre2
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/core-i7-extreme-memory-suppliers-datasheet.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/core-i7-extreme-memory-suppliers-datasheet.pdf Shows compatibility for RAM and also shows certified for use on ASUS P9X79 Deluxe but I do not see anywhere ASUS P9X79 LE. Is the Deluxe and LE considered the same?
Jose_H_Intel1
Apparently the ASUS P9X79 LE was not tested. You may cross-check with the lists provided in the link below or ask ASUS if they have tested with the LE any of the memory modules listed in the document linked above.
http://www.asus.com/Motherboards/P9X79_LE/HelpDesk_QVL/ http://www.asus.com/Motherboards/P9X79_LE/HelpDesk_QVL/
CStre2
Thank you, I posted something on the ASUS forums to see if I can get some guidance from them I just want some memory that is proven compatible and I don't know if I should go with the list from ASUS or the list from Intel as I cannot seem to see any that are common in the two lists.
Clint
Jose_H_Intel1
You can choose memory that has been validated for your motherboard model and that runs at 1333 MHz or 1600 MHz at 1.5 v.
CStre2
I want the RAM to run at 2133 Mhz using xmp and not have compatibility issues with the processor that will limit it.
Jose_H_Intel1
You may choose to run the memory at 2133 MHz; however, the processor officially supports up to 1600 MHz.
Going higher than the specifications indicate is considered overclocking.
