공지
16840 토론
IMC Test Fail CPU Diagnostic Tool
JSutt2
초급자
26,794 조회수
I just ran the Intel Diagnostic tool for my i5-6600k and it appears my computer passes every test besides the IMC test. It states as follows
IMC Test
Module Version: 1.0.7.64b.W
Start Time: Mon Feb 29 14:49:25 2016
Test Result - FAIL
--- Reading Memory Size ---
Unable to retrieve memory size.
-- - Memory Size Test Fail!!!-- -
End Time: Mon Feb 29 14:49:25 2016
Total Time: seconds: 0
Is this a grave issue ? Is it a bug or is it nothing to worry about ? I'm trying to get to the bottom of why my PC just randomly freezes/shuts down when playing video games on high graphics settings.
My GPU is a GTX 980 and my RAM is 16gbs so video games shouldn't be a problem let alone should my computer crash.
I ordered my PC premade from a selection of premade computers on PCCASEGEAR's website so I presume everything is compatible and no bottlenecking is occurring.
PC is water-cooled and temperatures are fine.
I have also set my bios to default (despite never fiddling with it in the first place)
If somebody could tell me if this IMC test could have anything to do with my problem consisting of my pc crashing during gameplay and if the IMC test fail could indicate other certain problems that would be great
(I'm currently thinking maybe it could be a GPU driver bug but cant be sure)
Any help or advice would be appreciated. Thank you.
0 포인트
1 솔루션
FHeik
새로운 기여자 II
21,442 조회수
Little to nothing is impossible in respect to possible reasons for problems of this kind, so we're talking about probabilities here.
As I've stated before, the characteristics of the issue you're experiencing usually implies a hardware failure. This mainly stems from the fact that the freezes occur so suddenly that the OS cannot even log any error related to the freeze anymore. The errors you see in Windows Event Log (41/6008) in theses cases are logged after the freeze, more specifically, after the next reboot.
If any kind of software tries to do anything it's not supposed to do in relation to the computer's hardware (for example trying to access memory by bypassing the OS), you'd get a bluescreen, not a freeze, and you'd see respective entries in Windows Event Log, or even get memory dumps which Windows is creating in such cases that could be analyzed with respective tools.
Again, this is how it usually works - there might be exceptions to the rule, but they're rare, and not easily to be identified.
The "foolproof" way of tackling this kind of issue usually is
  • to make sure the machine is running at stock settings (this includes making sure all components are working as required, for example fans - overheating can be a reason for freezing issues)
  • to make sure any software involved is up to date (esp BIOS, drivers, and the OS itself)
  • to make sure the machine is free of malicious / unwanted software (viruses etc)
  • if the problem persists even with these preconditions met, to replace hardware components one by one until the faulty / problematic one has been found
원본 게시물의 솔루션 보기
18 응답
Allan_J_Intel1
21,441 조회수
Please make sure you are currently running the latest IPDT version 3.0.0.25 and try again.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Download Intel® Processor Diagnostic Tool
Allan.
0 포인트
JSutt2
초급자
21,440 조회수
0 포인트
BSIlv7
초급자
21,440 조회수
I do have the same problem with my 6700K. Passes all the other tests, even the ones after IMC. Should I RMA the processor?
0 포인트
Allan_J_Intel1
21,442 조회수
Are you getting any blue screen? Does the computer lock up?
Allan.
0 포인트
BSIlv7
초급자
21,441 조회수
No, the system seems to be completely fine, that's what's bugging me. Does the 3.0.0.25 version support the 6700K? Is there a way to know if the IMC is really working? Thank you.
0 포인트
JSutt2
초급자
21,442 조회수
Whenever my computer freezes (usually 1-8 hours into a video game, depends on the videogame and its graphics settings so it seems) it may or may not repeat a loud drill like sound over and over (not all the time but is present with most of the freezeing) and my monitor displays the last thing I was doing while the game was playing, and I am rendered unable to do anything besides shut the computer down and restard. On ONE occasion my computer shut down all of a sudden and gave me a screen with white text, a blue background and a ":(" face of sorts (I presume this is a bluescreen).
I have never had any other problem with the computer.
At this rate I'm thinking of returning the pc for repair or a refund, however since I am unaware of what exactly is at fault here, I'm unsure whether or not ill be permitted to do that. </3
0 포인트
FHeik
새로운 기여자 II
21,441 조회수
Crashes like this (screen freeze, sound played at the time the freeze occurs repeats in a loop, only way to restart is to press & hold the Power On button, no related errors reported in Windows event log except the ones indicating a system power off/restart without a proper shutdown (Event ID's 41/6008)) usually indicate a hardware failure.
The cause(s) can be difficult to track down - could be anything from defective parts, hardware incompatibilities, erroneous BIOS or BIOS settings, overheating, up to incorrectly installed parts (such as RAM modules not properly seated in their slots).
If the causes aren't obvious, you usually have to take a trial & error approach in order to solve the problem, which usually consists of replacing suspicious parts / apply BIOS updates or settings / ensure parts are properly installed, until you identify the culprit.
0 포인트
JSutt2
초급자
21,442 조회수
Thanks for the info YseGuy. What would you recommend someone who isn't the best with handling hardware do at this point?
0 포인트
FHeik
새로운 기여자 II
21,442 조회수
Since the required error diagnostics can be cumbersome and requires some expertise / spare parts for testing, I'd say your best bet is to let your dealer or a local computer shop do the job. You can support them by supplying a detailed summary of your own observations / analysis results / actions you have taken to solve the issue.
0 포인트
JSutt2
초급자
21,442 조회수
Could my IMC test problem be that my motherboard has an IMC and the computer is using that instead?
0 포인트
FHeik
새로운 기여자 II
21,442 조회수
IMC = Integrated Memory Controller, means the memory controller is built into the CPU. This is the per design in Intel's recent Core i5 / i7 CPU's (Skylake microarchitecture).
It is also the reason why the specification of supported RAM mainly depends on the CPU, not the motherboard.
So I'd expect any motherboard supporting the Skylake chipsets (Intel 100 / 200 series chipsets, such as the Z170) to not have an external memory controller at all - it'd be redundant / not used anyway.
0 포인트
JSutt2
초급자
21,441 조회수
YseGuy I ran a memtest earlier with no problems being reported. Could this mean it may be a fault of the diagnostic tool? I just wanna get to the bottom of why that specific test fails. I have read that if my IMC was actually bad, that my computer would be having a lot more issues than what I have currently such as rejecting ram and such.
Update: I also found malware on my computer a moment ago, hoping this was the problem? Possibly could have affected my hardware?
0 포인트
JUnge
초급자
21,442 조회수
I found the same problem (IMC) with this tool. XMG P505 with i7-5700HQ and 32 GB RAM. The tools says "16GB installed" and IMC fails.
memcheck86 runs for 8 hours without any problem.
0 포인트
DouglasPC
초급자
21,442 조회수
Did you find your solution? I'm get similar issues with i5-4670k stock, on a Asrock z87 killer, with and w/o GPU, either or both sticks of RAM, and diags for CPU results pass most times, but I've seen IMC fail once, and have seem memory error message box once, with mostly crashed freeze ups, with or w/o sound loops. Fully updated, different BIOS versions & settings, and different SDD /M.2 drives.
0 포인트
FHeik
새로운 기여자 II
21,443 조회수
JBrig2
초급자
21,439 조회수
I am also experiencing the same problem reported by Intel Processor Diagnostic Tool (IPDT64 - Revision: 3.0.0.25.W.MP) on an Intel Core I7 6700K:
IMC Test
Start Time: Mon Mar 21 19:04:11 2016
Test Result - FAIL
End Time: Mon Mar 21 19:04:11 2016
In addition My 6700K is stuck to minimum clock frequency 800Mhz.
Are those problems related?
What corrective actions do you suggest?
Is my CPU defective?
0 포인트
BSIlv7
초급자
21,439 조회수
Just to help those failing th IMC test in the Intel Processo Diagnostic Tool. I had the same issue and what fixed it for me was updating my motherboard bios. After doing so I passed all the tests. I tried everything else before and my system was functioning fine. I passed all the other tests and tried different CPU testing softwares and none of them found any issues, but the IMC test kept failing. After the bios update it was all good. My motherboard is a Asus ROG Maximis VIII Hero. Hope this helps!
0 포인트
JBrig2
초급자
21,442 조회수
Upgrading to the latest BIOS on my ASUS z170 DELUXE MB did help as well for me.
I got rid of the IMC test failing.
I still have to struggle with th fact that my Core I7 6700K gest stuck to the minimum clock frequency.
0 포인트
응답
