16964 Discussions
Intel Core I7 12 gen Processor with Turbo Boost 4.9Ghz details require
RakeshKhatal
HI,
In 1 of our customer requirement they would be asking Intel Core I7 Processor with Turbo bosst upto 4.9Ghz Speed.
We have ntel® Core™ i7-1270P vPro™ Processor (with Intel vPro® Technology) / 18MB cache,
2.2 GHz up to 4.8 GHz with Intel® Turbo Boost Technology in our rugged Tablet CF-33.
Due to 4.8Ghz customer is not accepting our product.
Kidly suggest way forward to or if any mobile processor availble in Intel processor list with require specs then pls suggest.
Rakesh
<phone removed>
pressed_for_time
Valued Contributor II
At 4.8GHz maximum turbo boost the 1270P was the fastest 12th gen Core i7 mobile CPU available. There was no processor in the range that could boost up to 4.9 GHz at stock settings. Faster speeds were available in the 13th/14th gen processor range such as the Core i7 1370P which was a 5.20 GHz part.
RakeshKhatal
Thank You for your prompt reply.I have to give documented proof to customer as they are governement organisation.
Could you please confirm where can I get this information on Intel portal or any document be available to produce to customer.
Customer wants a document or website proof though which we can explain the situation.
pressed_for_time
The Intel web page listing all 12th Generation Core i7 mobile processors can be found here .
