16772 Discussões
Intel® Cryo Cooling Technology Gen 2 not support 13th
Parad1so
Principiante
1.326 Visualizações
=== Verbose logging started: 2022/10/24 13:21:35 Build type: SHIP UNICODE 5.00.10011.00 Calling process: C:\Users\Parad1so\Desktop\Intel_Cryo_Cooling_Technology_V2.0.2.805_2.exe ===
MSI (c) (34:8C) [13:21:35:739]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Users\Parad1so\AppData\Roaming\Intel Corporation\Intel(R) Cryo Cooling Technology 2.0.2.805\install\Intel(R) Cryo Cooling Technology.msi' against software restriction policy
MSI (c) (34:8C) [13:21:35:740]: SOFTWARE RESTRICTION POLICY: C:\Users\Parad1so\AppData\Roaming\Intel Corporation\Intel(R) Cryo Cooling Technology 2.0.2.805\install\Intel(R) Cryo Cooling Technology.msi has a digital signature
MSI (c) (34:8C) [13:21:35:777]: SOFTWARE RESTRICTION POLICY: C:\Users\Parad1so\AppData\Roaming\Intel Corporation\Intel(R) Cryo Cooling Technology 2.0.2.805\install\Intel(R) Cryo Cooling Technology.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (34:8C) [13:21:35:805]: Cloaking enabled.
MSI (c) (34:8C) [13:21:35:805]: Attempting to enable all disabled privileges before calling Install on Server
MSI (c) (34:8C) [13:21:35:807]: End dialog not enabled
MSI (c) (34:8C) [13:21:35:807]: Original package ==> C:\Users\Parad1so\AppData\Roaming\Intel Corporation\Intel(R) Cryo Cooling Technology 2.0.2.805\install\Intel(R) Cryo Cooling Technology.msi
MSI (c) (34:8C) [13:21:35:807]: Package we're running from ==> C:\Users\Parad1so\AppData\Roaming\Intel Corporation\Intel(R) Cryo Cooling Technology 2.0.2.805\install\Intel(R) Cryo Cooling Technology.msi
Etiquetas (1)
1 Responder
MDK_pt
Novato
1.264 Visualizações
Same problem
When Will Intel release the updated software for the 13900k
You have sent Roman der8baeur a beta version, Just release that the 13900k is out for time…… just release the software
Responder
