16774 Discussões
Intel DSA indicates new driver for Intel NPU but it has been installed
LT7879
Novo colaborador I
4.460 Visualizações
HI all,
I have installed the latest version of  lntel NPU  32.0.100.4181, but Intel DSA still showing to download the same version again. Any advise what to do?
Thank you
12 Respostas
AlHill
Superusuário
4.446 Visualizações
Never believe IDSA.  Just ignore it.
[IDSA needs to be abandoned, uninstalled and forgotten]
LT7879
Novo colaborador I
4.393 Visualizações
If I check the installation history, there is an error message Installation failed with error code 1000.
Any suggestion how to fix it?
thanks
ArchieD_Intel
Moderador
4.220 Visualizações
Hi LT7879,
When did the issue start? Was it after a specific update?
What are the troubleshooting steps that you tried so far?
Can you please provide me a screenshot of the error?
Is the Intel NPU driver the only issue?
Have you tried uninstalling the NPU driver and use the IDSA?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
LT7879
Novo colaborador I
4.196 Visualizações
Hi Archie,
The issue start after installing the NPU Driver listed at the IDSA website.
I uninstall the NPU driver, and choose clean uninstall. Reinstall it again, Uninstall it, and reinstall it again.
Yes for now only intel NPU
Yes, several times. And just for your information, sometimes I cannot click any button at the Intel DSU page, so I tricked it to go other page and return to the page and it will work.
Please find attached the SSU and the screenshot of the error message.
ArchieD_Intel
Moderador
4.069 Visualizações
Hi LT7879,
Thank you for the update. Please follow these steps to address the issue:
  1. On the IDSA scan page, click "Refresh Results" located in the left-hand menu.
  2. Clear your browser cache by pressing Shift + F5, then attempt to rescan using IDSA.
  3. If the issue persists, verify that both the Intel® DSA Service and Intel® DSA Updater service are running. To do this, open Windows Search, type "Services," and locate Intel(R) Driver & Support Assistant. Ensure the status for both services is "Running." If not, right-click on the service and select "Start" to initiate it.
Additionally, check for any pending Windows updates by navigating to Windows -> Settings -> Updates -> Security. If your system hasn't been restarted recently, consider doing so. You can check the system's uptime by opening Task Manager, going to the Performance tab, selecting CPU, and viewing the Up Time displayed in days/hours/minutes/second's format.
Archie D.
LT7879
Novo colaborador I
3.944 Visualizações
I have done it, but the error message code 1000 still remains. Please advise
William41
Principiante
3.898 Visualizações
I believe the error 1000 issue is caused by the Current NPU version number is the same as the New NPU version number.
ArchieD_Intel
Moderador
3.022 Visualizações
Hi LT7879,
Thank you for the feedback. I will investigate this and will get back to you once a resolution is available. Thank you for your patience and understanding.
Hi William41, for us to address your concern and to avoid any confusion, please create a separate thread and one of the supports will be helping you.
Archie D.
ArchieD_Intel
Moderador
2.904 Visualizações
Hi LT7879,
Please check your email inbox, as we have sent you a message regarding our concern.
Thank you and have a great day ahead!
Archie D.
ArchieD_Intel
Moderador
2.175 Visualizações
Hi LT7879,
Did you have a chance to review the previous post? Please feel free to reach out if you have any questions. Thank you.
Archie D.
LT7879
Novo colaborador I
2.153 Visualizações
Hi Archie,
Sorry for the late response. As per today, Intel DSA already indicated no new driver, although in the history it still said the last installation is error 1000. But for now we can close it. Thank you
ArchieD_Intel
Moderador
2.111 Visualizações
Hi LT7879,
Thank you for the update. As you've requested, I will now close this thread. If you require further assistance, please feel free to submit a new question, as this thread will no longer be actively monitored.
Archie D.
Responder
