- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I received a pop up indicating that my ID&SA Tray had been updated and a reboot was required to finish the update. I rebooted my machine several times but continued to receive the pop up. I thought a fresh install of the ID&SA would be the cure. I uninstalled the ID&SA using the ID&SA Uninstaller. When I tried to install the latest version of the ID&SA, the setup failed. The message I received was:
0x00000783 - Service 'Intel(R) Driver & Support Assistant' (DSAService) could not be installed. Verify that you have sufficient privileges to install system services.
I have attached the log associated with the error and a screen shot of the error. Any thoughts on what is causing this would be greatly appreciated. Thanks in advance,
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thank you so much for your help! I was able to install the Intel DSA tool without issue. I wasn't installing it as an administrator and I think that was my problem. Thanks again!
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
PearlWhiteFatBoy, Thank you for posting in the Intel® Communities Support.
For this specific scenario, we recommend to use any of the following browsers: Chrome, Firefox or Edge.
Then you can also try to clear the browser cache and try to install the Intel® DSA tool.
To install the Intel® Driver Support Assistant version 21.2.13.9, please run the system as administrator:
https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant
Once you get the chance, please let us know if you were able to successfully install the tool.
Albert R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
PearlWhiteFatBoy, You are very welcome, thank you very much for providing those results.
Perfect, excellent, we are glad to hear that you were able to install the Intel® Driver Support Assistant as an administrator and now the tool is working properly on your system.
Any other inquiries, do not hesitate to contact us again.
Albert R.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
