Ankündigungen
16845 Diskussionen
Intel Driver & Support Assistant is not working
enzodsqdqs
Einsteiger
4.609Aufrufe
hi i wanted to dowload some pilots for my pc but my Intel Driver & Support Assistant is not working i dont know why i downloaded the latest version of intel driver assistant by nothing and of course i tryed to unistall and redownload but nothing
and when I reload the page it doesn't work
here is my processor i5-3470S 2.90ghz
and i dont have gpu
please help me
Beschriftungen (1)
1 Lösung
DeividA_Intel
Mitarbeiter
4.429Aufrufe
Hello enzodsqdqs,
In order to help you further, I will appreciate it if you provide the following information:
1. What do you mean by not working? Is it not scanning, is it not downloading the updates? Any error message?
2. After using the Intel® Driver & Support Assistant (Intel® DSA) uninstaller, did you check the "Apps & Features" to confirm that it was completely deleted?
3. Can you try any other browser (Firefox or Edge)?
4. Logs from the Intel® Driver & Support Assistant (Intel® DSA):
- log files can be found at C:\ProgramData\Intel\DSA.
Deivid A.
Lösung in ursprünglichem Beitrag anzeigen
9 Antworten
AlHill
Superuser
4.598Aufrufe
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
enzodsqdqs
Einsteiger
4.588Aufrufe
hi thank you to respond
below u can see the text has wanted
DeividA_Intel
Mitarbeiter
4.534Aufrufe
Hello enzodsqdqs,
I would like to let you know that your Intel® Core™ i5-3470S Processor is discontinued and Intel does not provide support for this product as well as new drivers.
However, I will help you only with the issue related to the Intel® Driver & Support Assistant (Intel® DSA). In order to better assist you, please provide the following:
1. Was Intel® Driver & Support Assistant (Intel® DSA) working properly before?
2. Did you use the Intel® Driver & Support Assistant (Intel® DSA) uninstaller?
- Uninstaller: https://downloadcenter.intel.com/download/30496?v=t
- Tool: https://downloadcenter.intel.com/download/28425
3. Are you using a supported browser (Firefox, Chrome, or Edge)?
4. You can see more information at the following link:
- https://www.intel.com/content/www/us/en/support/articles/000026895/software/software-applications.html
Deivid A.
DeividA_Intel
Mitarbeiter
4.516Aufrufe
Hello enzodsqdqs,
Were you able to check the previous post? Please let me know if you need more assistance.
Deivid A.
enzodsqdqs
Einsteiger
4.478Aufrufe
hi thank you for your respond
1 so yes intel dsa worked before
2 i used dsa installer
3 i use google
DeividA_Intel
Mitarbeiter
4.458Aufrufe
Hello enzodsqdqs,
Thank you for the information provided
Deivid A.
DeividA_Intel
Mitarbeiter
4.430Aufrufe
Hello enzodsqdqs,
Deivid A.
enzodsqdqs
Einsteiger
4.379Aufrufe
ok
a lot of compliment for you Deivid
the problem was the browser. im actually using Brave so it block some features
and i move to edge and dsa scan worked
thank you a lot man
DeividA_Intel
Mitarbeiter
4.359Aufrufe
Hello enzodsqdqs,
I am glad to hear that the issue was fixed by changing the browser (Edge), I will proceed to close this thread, however, do not hesitate to create a new one if you need further assistance with our products.
Deivid A.
Antworten
