链接已复制
9 回复数
Hello sharoak,
Thank you for posting on the Intel* Community.
I will proceed to check internally if the option was removed, please expect an update soon.
Maria R.
Hello sharoak,
Thank you very much for your patience.
Please check the below information:
- When you open the XTU, do you see the ISO (Intel® Speed Optimizer) tab? If Basic Tuning isn’t displaying it should display the ISO (Speed Optimizer) tab instead. They are having similar features
- If you can't see it then most likely you would need to wait for a BIOS update from the OEM (Mobo Manufacturer) to enable Intel® Speed Optimizer.
- Alternatively, you could switch to Intel Performance Maximizer for easy overclocking.
Maria R.
Hello sharoak,
Maria R.
