16855 Discussions
Intel Extreme Tuning Utility not showing progress indicators
funkeemonkee
I'm using
11700K
Aorus Z590 Elite AX
current version of XTU 7.3.0.33
not sure why, but its not showing any progress indicators.
please help
David_G_Intel
Hello funkeemonkee
Thank you for posting on the Intel️® communities.
Please provide the following informaiton:
  • Intel® System Support Utility (Intel® SSU)  results
  • Did it work before?
  • Did you make any changes to your system recently?
  • Which troubleshooting steps did you try to resolve this problem?
David G
Intel Customer Support Technician
funkeemonkee
Hi @David_G_Intel
apologies for the delay - here's the file
  • Did it work before? - its the first time on this new build
  • Did you make any changes to your system recently? - nope
  • Which troubleshooting steps did you try to resolve this problem? - you're the first
btimofte
Not related to the post 100% , but sometimes the XTU shows for my CPU -3.6 Ghz lol
David_G_Intel
Hello @funkeemonkee
Were you able to check the previous post?
Let us know if you still need assistance.
@btimofte please create a new thread with more information to assist you.
Best regards,
David G.
David_G_Intel
Thank you for the information provided, please follow these steps:
If it still doesn't work, please share a video of the problem to continue with the investigation and replicate it here in our labs.
David G
David_G_Intel
David G.
funkeemonkee
Hi thanks for your reply.
I've got the latest XTU
basically when i Run benchmark.... nothing is showing except the spinning wheel.
attached is the video
https://youtu.be/T9uwT2iDhR0
David_G_Intel
Thanks for the video and the information provided, we are currently working on this request, updates will be posted on the thread.
David G.
David_G_Intel
After checking the information provide we noticed the following:
David G.
funkeemonkee
Hi David,
I did all of the following
1. reverted / switched off XMP
2. only intel XTU installed + reinstalled to latest version
same problem. XTU doesn't show anything .
David_G_Intel
Thank you for the information, we will continue with the investigation and post the updates on this thread.
David G
David_G_Intel
Hello @funkeemonkee
We tried to replicate this problem with different configurations but we did not get the same result as you, the best option in this case is to do a clean installation of the operating system using a new image of Windows * (not used before).
David G
David_G_Intel
Hello @funkeemonkee
Did you test the recommended steps? Let us know the outcome.
David G
David_G_Intel
David G.
