16800 Discussions
Intel I5-1235U Temperauture
Infanted
Hello, I just purchased an Asus Vivobook 15 laptop with this processor, the laptop is model F1504ZA-SB54, when turned on it maintains temperatures of 50°C in the processor, I am new to this, I don't know if it is good or it is too much to just start without any process. Thanks in advance
Jose_Intel
Hello @Infanted
Thank you for posting on the Intel️® communities.
We understand your concern about the temperature of your Intel® Core™ i5-1235U Processor, we will be more than happy to assist you.
Please keep in mind that Intel® Turbo Boost Technology opportunistically accelerates processor performance for peak loads and it does not sustain the turbo frequencies.
The processor usage depends on the applications used in the system. When the processor usage is high, the temperature of the processor also rises. Intel® Processors have built-in thermal protection. If the processor gets too hot, the built-in protection slows down (throttling) and eventually shuts down the processor.
Please contact the system manufacturer to understand the system’s normal operating temperature range and to report unexpected behavior of the system.
Jose B.
