16764 Discussions
Intel LGA 2066 is only with ITM?
Dear Intel, why you deny from solder in 7 generation HEDT, users buy HEDT CPUs because then have solder under IHS!
Hello NX_ECX,
Thank you for contacting the Intel community.
Please allow me to further investigate this for you.
Ivan U.
Hello NX_ECX ,
I would like to provide the results from the consults done regarding your questions.
  1. Intel Thermal Interface Material (TIM) meets the processor design specifications.
  2. We do not recommend running outside the processor specifications, such as by exceeding processor frequency or voltage specifications or removing of the integrated heat spreader (IHS) (sometimes called "de-lidding"). These actions will void the processor warranty.
  3. For HEDTs (High-End Desktops) Intel® processors, the IHS (Internal Heat Spreader) and other components meet the processor design specifications. Every customer can be sure about the Intel® products high quality.
I would also like to apologize for the late reply.
If further questions are present, feel free to contact us back.
Esteban C
Hello NX_ECX
This is to do a follow up to your post, do you happen to have further questions about this matter?
Esteban C
