Intel PM
Aorus
Principiante
7.441 Vistas
Hello.
I'm using a z390 aorus ellite mb(updated) and a i-5 9600K
I wanted to use intel performance maximizer.
But I can't get to use it, it says:
"System requirements not met
A GPT formatted bootable disk is required."
Any help with this one?
0 kudos
8 Respuestas
AlHill
Superusuario
7.438 Vistas
What version of W10 are you using?  1909?  2004?
Yes, a GPT partition is necessary.  Are you booting legacy?
Doc
Aorus
Principiante
7.434 Vistas
1903
wym booting legacy ?
AlHill
Superusuario
7.432 Vistas
So we can have more information about your system,  Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (look at the instruction under the reply window).
Doc
Aorus
Principiante
7.429 Vistas
Here It Is thank you so much for your help
AlHill
Superusuario
7.424 Vistas
Ok, your bios is set to LEGACY.  We need to get you to UEFI.  We would also like to have you update your windows 10 to 1909 or 2004.
But first, UEFI boot.  To do this without a  clean install, you need to run MBR2GPT.  Here is a link on how to do this.
https://www.tenforums.com/tutorials/81502-convert-windows-10-legacy-bios-uefi-without-data-loss.html
Once you do this, and reboot, you must immediately enter your bios and change the boot mode from LEGACY to UEFI.  Once you have done that, you can boot to the OS, and you will now be a UEFI boot, with a GPT disk rather than an MBR disk.
Doc
Aorus
Principiante
7.421 Vistas
I keep getting this error
"ERROR: MBR2GPT can only be used from the Windows Preinstallation Environment. Use /allowFullOS to override."
Now I get this
C:\WINDOWS\system32>mbr2gpt.exe /disk:4 /convert /allowFullOS
MBR2GPT will now attempt to convert disk 4.
If conversion is successful the disk can only be booted in GPT mode.
These changes cannot be undone!
MBR2GPT: Attempting to convert disk 4
MBR2GPT: Retrieving layout of disk
MBR2GPT: Validating layout, disk sector size is: 512 bytes
Disk layout validation failed for disk 4
MBR2GPT: Conversion failed
Aorus
Principiante
7.416 Vistas
this is the error
2020-06-25 14:06:27, Error ValidateLayout: Wrong boot partition count, expected 1 but found 0.
2020-06-25 14:06:27, Error Disk layout validation failed for disk 0
2020-06-25 14:06:36, Error ValidateLayout: Wrong boot partition count, expected 1 but found 0.
2020-06-25 14:06:36, Error Disk layout validation failed for disk 2
2020-06-25 14:06:52, Error Cannot find OS partition(s) for disk 1
2020-06-25 14:08:35, Error ValidateLayout: Wrong boot partition count, expected 1 but found 0.
2020-06-25 14:08:35, Error Disk layout validation failed for disk 2
2020-06-25 14:10:26, Error ValidateLayout: Unexpected partition style, expected 0, found 1
2020-06-25 14:10:26, Error Disk layout validation failed for disk 5
2020-06-25 14:10:30, Error Cannot find OS partition(s) for disk 1
2020-06-25 14:18:23, Error ValidateLayout: Wrong boot partition count, expected 1 but found 0.
2020-06-25 14:18:23, Error Disk layout validation failed for disk 4
2020-06-25 14:19:55, Error ValidateLayout: Wrong boot partition count, expected 1 but found 0.
2020-06-25 14:19:55, Error Disk layout validation failed for disk 4
AlHill
Superusuario
7.406 Vistas
One of the Intel support engineers will assist you.
Doc
Responder
