17013 Discussions
Intel PTAT Tool: wrong sorting of columns in csv log for MEM data
Edgar-Ramon
Hi Intel Community,
I’m currently running PTAT - Server Edition 4.6.0 on a CentOS Stream 9 machine with kernel 6.10. I’m experiencing a couple of issues when parsing the CSV log file after running a specific command.
The command I’m using is:
./ptat -ct 1 -mt 3 -l 1 -ts -t 3600 -mon -filter 0x3F -i 10000000 -log -csv
After parsing the generated CSV log for memory-related data, I’ve encountered the following two issues:
  1. MEM info values appear to be one column displaced in the CSV output.
  2. Write bandwidth is reported higher than read bandwidth. I’m not sure if this discrepancy is due to sorting issues in the CSV, a utility issue, or a parameter misconfiguration.
Has anyone encountered similar issues or can provide insight into what might be causing these discrepancies?
Thanks in advance for your help!
Earl_Intel
Hi Edgar-Ramon,
To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
  • May I know the make and model of your processor?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing.
Earl E.
Earl_Intel
Hi Edgar-Ramon,
Earl E.
Earl_Intel
Hi Edgar-Ramon,
Earl E.
