16770 Discussions
Intel Performance Maximizer Error: Failed to create partition
cmart49
I have a brand new 9900k that I wanted to utilize the Intel Performance Maxmizer to overclock. However, I receive the same error each time I try to, despite having more than enough space to create a 16gb partition.
After being asked "Are you sure if you want to shrink your partition [C:NTFS 465.16GB[132.54 GB free]]" the following error appears: "Failed to create partition. Unable to shrink partition. Please check your disk and try again."
Screenshot attached.
PC specs:
BIOS drivers are updated, all settings were set to optimized defaults before installing IPM. Thank you in advance.
Alberto_R_Intel
cmart49, Thank you for posting in the Intel® Communities Support.
Which Windows* 10 version are you using, is it 1809?
Did you install Windows* using a GPT drive? GUID Partition Table (GPT) disks use Unified Extensible Firmware Interface (UEFI) allowing you to have more than 4 partitions on each disk, this is needed for the tool to run properly.
Additionally, there are some BIOS requirements:
  • BIOS needs to be in default unlocked configuration
  • Intel® Hyper-Threading Technology must be enabled
  • Intel® Turbo Boost Technology 2.0 must be enabled
  • Boot mode must be UEFI
  • Enhanced Intel SpeedStep® Technology must be enabled
  • Intel® Watchdog timer driver must be enabled
In order to confirm those details you can always get in contact directly with Gigabyte for them to verify those settings in the BIOS:
https://www.gigabyte.com/Support
Please let us know if despite the fact that the PC complies with all those requirements the problem persists so we can further assist you.
Alberto R.
cmart49
Thanks for the response, Alberto. I am running Windows 1809, and indeed installed Windows using a GPT drive (screenshot attached).
I went into my BIOS settings and confirmed that i'm booting UEFI and the other settings are enabled. Some of them were set to AUTO, so I changed them to Enabled with no success.
Is there anything else I can try?
Alberto_R_Intel
cmart49, You are very welcome, thank you very much for providing that information.
Yes, one more thing that we can check is, if the latest BIOS version provided by ASUS is the one installed on the board, which is F7:
https://www.gigabyte.com/Motherboard/Z390-AORUS-ULTRA-rev-10#support-dl-bios
Alberto R.
cmart49
Alberto, I was able to get the tool to work after creating a 20GB unallocated partition at the end of the drive. Thank you for the help!
Alberto_R_Intel
cmart49, thank you very much for letting us know those results.
Perfect, excellent, it is great to hear that after creating a 20GB unallocated partition the Intel® Performance Maximizer is now up and running and working properly, it should work just fine from now on.
Any other inquiry, do not hesitate to contact us again.
Alberto R.
