Hi I'm currently inspecting all the components of my pc.
This due to short freezes of the system every now and then (like less then a second) while there is a freeze everything locks up, audio becomes noise, video freezes also the cursor and in games, while watching a movie, doing nothing etc so really everything.
Maybe you could point me in the right direction for that problem.
What I was trying this time was your IPD Tool
So when I installed the software and started it, it happily started doing all kinds of checks until the Cache Test
It just sat there for 5 minutes " --- Reading Cache Size --- "
And after that it showed me this:
When I disabled the cache test the whole test ran just fine and I was greeted with a green window at the end.
These are my specs:
Windows 8 x64 Pro latest updates.
CPU: I5 3550
Motherboard: Asus P8Z77-V (latest BIOS 1908, Management Engine 8.1 and latest Intel Network Rom https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22026 NVM Update Utility for Intel® 82579V Gigabit Ethernet PHY Network Connection)
SSD: Crucial M4 128GB
HDD: Hitachi 5K3000 2TB
HDD: Seagate Barracuda ST3000DM001 3TB
GPU: Integrated at the moment while I sort out where the problem is. Normally it is SLI Asus GTX670 DCII
PSU: Corsair AX760i (the problems existed before I had this power supply)
RAM: 16GB (So 2x) Corsair CML8GX3M2A1600C9
So, does this mean something is wrong with my CPU?
Or is this a bug in the software.
UPDATE: Yesterday I removed my GPU's and went integrated, the freezes were dramatically reduced, but the problems persist, this time under load (e.g. playing games). So this can plausably only mean 2 things, it's really my cpu or my motherboard.
UPDATE 2: Nope it also happens during no load situations...
- 標籤:
- Tools
連結已複製
I have the same issue.
but, the test passes if I un-check the cache test item in the test configuration software,
CPU: Xeon E3 1265L v2
Motherboard: Supermicro X9SCM-iiF (Chipset: C204, BMC & IPMI)
SSD: Plextor M5S 256GB
HDD: None
GPU: Matrox g200eW on motherboard
RAM: 16GB (8GB x 2)
Maybe Hyper-V ? Yes I am using Hyper-V.
Hello Ellos,
We haven't heard about any problem with this software; however I'm going to check it out and report it if it's necessary.
In the mean time, you may want to use a 3rd party software such as CPU-Z.
Regards.
Ellos,
It is possible to have a defective processor, so in order to find out if the unit is or not defective you will need to troubleshoot the system with minimum configuration (processor, motherboard, power supply and 1 memory stick)
Also, make sure your motherboard has the latest BIOS version.
You may want to do a clean installation of the Operating System using the latest drivers, in order to discard if this is a software issue instead of a hardware failure.
If you continue having the same behavior, feel free to contact your local support group for assistance on replacing your product http://www.intel.com/p/en_US/support/contact/phone http://www.intel.com/p/en_US/support/contact/phone
Regards.
