16784 토론
Intel XTU VCore issue when loading "Default" profile
Anonymous
해당 사항 없음
7,450 조회수
Hello @all!
I recently discovered an issue when loading the "Default" profile of the XTU tool. When this profile has been re-applied after having changed one of the core settings, the Package TDP goes way above it's expected value. This seems to be due to a raised core voltage.
Here is what I have done to reproduce this issue:
Run #1) Perform Cinebench R20 (multicore) run with default settings -> TDP = 155 - 160W, VCore = 1.200 - 1.215V
Run #2) Set PL2 = 240W, run Cinebench R20 again -> TDP and VCore remain unchanged
Run #3) Load "Default" profile in XTU software (PL2 = 251W) and  run Cinebench R20 again -> TDP = 230 - 240W, VCore = 1.380 - 1.390V
So loading the default settings results in 80W higher package TDP because of the apllied core voltage setting. When settings PL2 = 251W manually instead of loading the default profile, there is no such strange behavior.
Here are some system specs which may help:
CPU: Intel Core i7-11700K
Mainboard: ASRock Z590 Steel Legend (BIOS version: 1.30)
RAM: Crucial Ballistix 2x8GB DDR4 3600 CL16
OS: Windows 10 20H2 (Build 19042.867)
INF driver: 10.1.18634.8254_Public
Intel Management Engine driver: 15.0.21.1549_CONS_SW_DCH
Intel XTU v7.3.0.33
Mainboard BIOS set to default settings, except RAM (X.M.P. loaded); CPU running with default settings (default clock settings, VCore = auto, PL1 = 125W, PL2 = 251W, Tau = 56s)
I hope this issue has not been discussed yet in the forum (a search here led to no result).
XY_AB
0 포인트
10 응답
Anonymous
해당 사항 없음
7,354 조회수
Can anybody confirm this problem?
0 포인트
David_G_Intel
중재자
7,334 조회수
Hello XY_AB
Thank you for posting on the Intel️® communities.
For testing, run the XTU benchmark instead of Cinebench, share screenshots of the results and the report of the Intel® System Support Utility (Intel® SSU)
  • Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows
  • Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
What are the exact settings changed in the software, before loading the default profile?
David G
Intel Customer Support Technician
0 포인트
Anonymous
해당 사항 없음
7,325 조회수
Hello David,
I only changed "Turbo Boost Short Power Max" (PL2) from 251W (default setting) to 240W. Just a minor adjustment, which in my opinion has no noticeable effect, because this limit is not reached when running Cinebench or XTU Benchmark.
When running XTU Benchmark instead of Cinebench, behavior is the same. Before loading the default profile, power consumption peaked at 137W. After loading default profile, peak power consumption was 189W. Please look at the attached screenshots, there you can see the Package TDP and Core Voltage graphs for both described scenarios.
XTU_BenchmarkRun1.png - run 1 before loading default profile
XTU_BenchmarkRun2.png - run 2 after loading default profile
I also attached the report of Intel SSU.
XY_AB
0 포인트
David_G_Intel
중재자
7,279 조회수
Hello XY_AB
We're testing this on our side, we will keep you posted.
David G
0 포인트
David_G_Intel
중재자
7,227 조회수
Hello XY_AB
We tried to replicate this with the information provided, but we didn't get the same issue. Please confirm that you're using the default profile without any changes to it, and if it's the first time you try it let us know if you still see the increase.
David G
0 포인트
Anonymous
해당 사항 없음
7,217 조회수
The default profile was not changed in any way (don't know how to do that or if it is even possible). Unfortunately, the problem still exists, even after I updated Mainboard's BIOS / UEFI to version 1.40.
0 포인트
David_G_Intel
중재자
7,192 조회수
We're working on this request, the updates will be posted on the thread.
David G
0 포인트
David_G_Intel
중재자
7,149 조회수
After running some test and checking the information provided, we recommend that you set the entire system to default settings for this scenario. Disable any overclocking settings, Voltage, frequency changed, XMP, and Run the Intel® PDT to check the processor status.  If it passes all tests, the processor is working as it should.
If your system continues to show this instability with the TDP-W, you should consult with the motherboard manufacturer the proper configuration since the XTU relies on the BIOS controls and targets defined by each motherboard manufacturer.
David G
0 포인트
Anonymous
해당 사항 없음
7,140 조회수
@David_G_Intel wrote:
"... Disable any overclocking settings, Voltage, frequency changed, XMP, and Run the Intel® PDT to check the processor status."
I did not change voltage or frequency settings. Just loaded XMP settings. But the issue also occurs without XMP (all BIOS / UEFI settings = default).
In other words: for you it's not possible to reproduce to issue.
If this may help: rebooting Windows solves the problem. After OS reboot, the default profile seems to apply the correct voltage, so TDP is as expected, too.
0 포인트
David_G_Intel
중재자
7,121 조회수
Thanks for the clarification. Remember to check with the OEM for proper settings as the XTU is based on the BIOS controls and targets defined by each motherboard manufacturer.
David G
0 포인트
응답
