16762 Discussions
Intel Xeon-D 1541 doen't work on 2400MHz with 2x16GB Memory
AMolc
Hello all,
Intel Xeon-D 1541 doesn't work on 2400MHz with 2x16GB memory (P/N: BLS16G4D240FSC - Crucial DRAM 16GB DDR4 2400 MT/s (PC4-19200) CL16 DR x8 Unbuffered DIMM 288pin)
It running only on 2133MHz.
Could you help me please...
Hello, alexey .iowa.
Thank you very much for sharing your issue with the Intel® Communities Team.
For me to perform a deeper research, can you please confirm your OS and Motherboard model?
Antony S.
AMolc
Hello, Antony!
I use Supermicro X10SDV-F-B (with Intel Xeon-D 1541) Motherboard (bios 1.2c ver).
About OS i will use CentOS 7, but frequency i checking from BIOS.
Alexey
Thank you very much for that information alexey .iowa.
Let me share with you that indeed this processor will run at 2400MHz a per its https://ark.intel.com/products/91199/Intel-Xeon-Processor-D-1541-12M-Cache-2_10-GHz specifications as your http://www.supermicro.com/products/motherboard/xeon/d/x10sdv-f.cfm motherboard nonetheless, after doing some research I have found that some users fixed this problem with this same mainboard and processor after a BIOS update. Can you try getting in touch with https://www.supermicro.com/support/index.cfm Supermicro* Support to double check if there is a BIOS update for your system. Please share with us the results.
Antony S.
AMolc
Thank you very much for your analyze.
Yes, i have updated the motherboard to the last version 1.2c BIOS. It didn't help.
Alexey
Thank you for verifying that alexey .iowa.
At this point, I would highly recommend you to get in touch directly with https://www.supermicro.com/support/index.cfm Supermicro* Support and double check if there is any limit set on the mainboard or if this is a known issue for them and they will release an update to fix it. This processor is embedded into this Motherboard so this can be actually set by the system manufacturer.
Antony S.
AMolc
Thank you Antony!
I did it at the same time and they given me answer, with 16GB memory rank for 2400MHz speed i need to use 4 slots.
I checked it's true.
Alexey
