Hello grahamleigh4,
It appears that you're experiencing with Intel Driver & Support Assistant. To address the issue effectively, kindly share the information below.
1. Was this working fine before?
2. Did you make any recent changes to the system?
3. Which browser/s are affected?
4. What version of Intel Driver & Support Assistant are you running?
5. Have you performed any troubleshooting steps?
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Hello grahamleigh4,
Jed G.
Hi Jed D,
- Yes, many times, a message came up, I went to web page, and it worked just fine
- Nord VPN, but that is turned off
- I only use chrome
- The latest, just uninstalled it, reinstalled it, same problem
- Not sure how to trouble shoot this, apart from above
- I have attached a diagnostic file, but it is too advanced for me to understand.
The intel Graphics software - independant, not web based, dark blue box colour, works just fine.
Just a thought, the web based updater sometimes offers graphic updates as well as, say, bluetooth drivers - could this be in conflict with the one above
Coincidenly it has just flagged 4 more updates
Graham
Hello grahamleigh4,
Thank you for sharing all this information. To further troubleshoot the issue, kindly follow the outlined steps below.
- Go to Browser Settings
- Click on Privacy and Security
- Navigate to Site Settings
- Scroll down to Permissions
- Select Additional Permissions
- Scroll to the last option, Local Network Access
- Add intel.com under Customized Behaviors
- Once the domain is added under “Customized Behaviors,” click on the three dots next to it and select “Allow.”
If the issue persists, please let me know.
Best regards
Jed G.
