告知
16851 ディスカッション
Intel i9 14900KF - Temp behavior
Norbury-DK
ビギナー
3,445件の閲覧回数
I know there are more posts about the following.
But i need to ask as well,
The cpu package temp. on my 14900kf, raises to 80c-95c with in a second, when performing a stress test, and drops to 30c-40c when the test is over.
The coolant temp in my cooler raises to max 40c.
Is this normal behavior?
Is there something i'm missing?
I have attached test from Intel Extreme Tuning, System Support Util and Intel processor Diag Tool.
Thanks in advance
/ Steve
0 件の賞賛
1 解決策
JayB_Intel
従業員
3,383件の閲覧回数
Hello Norbury-DK,
Thank you for posting in the Intel® Communities Support.
Please be advised that you are stress testing the processor, and seeing thermal throttling for a short duration (~1 second) despite happening on multiple instances is normal during the test. The ideal operating temperature for a computer system on idle is around 35-45°C, but it is not applicable to all system since every component are different from one user to another. As long as your system is running at a consistent lower temperatures outside the stress test, your system should be working as per normal.
Jay B.
元の投稿で解決策を見る
1 返信
JayB_Intel
従業員
3,384件の閲覧回数
Hello Norbury-DK,
Jay B.
返信
