16803 Discussions
Intel i9 7920x processor is running at about 92-93C
KSchw3
My i9 7920x processor is running at about 92-93C when I'm rendering video and doesn't drop below 38-40C when nothing is going on. These temps seem high. I'm using a Cooler Master MasterLiquid 240 to cool the cpu. Any suggestions for lowering the temperature?
Here's a test I just ran:
--- IPDT64 - Revision: 4.1.0.28
--- IPDT64 - Start Time: 7/26/2018 4:30:09 PM
CPU1
Genuine Intel CPU Test
Module Version: 1.0.15.64b.W
Start Time: Thu Jul 26 16:30:09 2018
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Thu Jul 26 16:30:09 2018
Total Time: seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.18.64b.W
Start Time: Thu Jul 26 16:30:10 2018
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i9-7920X CPU @ 2.90GHz
Intel(R) Core(TM) processor detected..!!..
End Time: Thu Jul 26 16:30:10 2018
CPU1
Cache Test
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 1024
- Detected L3 Cache Size --> 16896
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Module Version: 1.0.20.64b.W
Test Result - PASS
DetectUtils64 DLL Version - 1.1.2
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
IMC Test
Module Version: 1.0.11.64b.W
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 32.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Thu Jul 26 16:30:11 2018
Total Time: seconds: 1
CPU1
Parallel_PrimeNum_i9 Test
Module Version: 1.0.0.8
Start Time: 7/26/2018 4:30:11 PM
Test Result - PASS
Module Math_PrimeNum.exe Completed - Pass
Prime Number Generation Test
Start Time: Thu Jul 26 16:30:11 2018
AVX is supported in your OS
Max AVX supported = AVX512
Test Result - PASS
Operation Per Second: 89291
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Thu Jul 26 16:30:31 2018
Total Time: seconds: 20
End Time: 7/26/2018 4:30:31 PM
CPU1
Parallel_FP_i9 Test
Start Time: 7/26/2018 4:30:31 PM
Test Result - PASS
Module Math_FP.exe Completed - Pass
Floating Point Test
Module Version: 1.0.17.64b.W
Start Time: Thu Jul 26 16:30:31 2018
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 234.26
Error: 0
--- Floating Point Test Passed!!!---
End Time: Thu Jul 26 16:30:51 2018
Parallel_FP_i9
End Time: 7/26/2018 4:30:51 PM
CPU1
Parallel_Math_i9 Test
Start Time: 7/26/2018 4:30:51 PM
Test Result - PASS
Module AVX.exe Completed - Pass
Module FMA3.exe Completed - Pass
Floating Point Test
Start Time: Thu Jul 26 16:30:51 2018
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.13
Error: 0
End Time: Thu Jul 26 16:32:21 2018
Total Time: seconds: 90
Test Result - PASS
Operation Per Second: 35939
Error: 0
End Time: Thu Jul 26 16:32:21 2018<...
Hello schwall26
Thank you for joining the community.
I see that you are having concerns about the temperature that that is reaching the processor, allow me to help you investigate the case.
Looking into the Intel® processor diagnostic tool report that you have shared with us is no noticing that the processor is not reporting any failure, I also verify the processor specs on the following link : https://ark.intel.com/products/126240/Intel-Core-i9-7920X-X-series-Processor-16_50M-Cache-up-to-4_30-GHz https://ark.intel.com/products/126240/Intel-Core-i9-7920X-X-series-Processor-16_50M-Cache-up-to-4_30-GHz I am noticing that the Tjunction for this unit is 95 C, in this case, the processor is working under the specs, upon verifying the Thermal Design Power of the processor that is 140w; I would suggest verifying with master cooler if the cooling system that you have is capable of dissipating that heat/power.
Leonardo C.
KSchw3
Thanks for the reply!
Yes, I just checked. The model I have is good for up to TDP 230W, which is also why it's a bit concerning that it was running that hot.
I have had a couple BSODs with WHEA_uncorrectable_error over the past few days too. So I am trying to figure out what's going on. I updated all of my drivers and went into BIOS to make sure the enhanced Turbo for the i9 was off. I left Intel Turbo on. Even though those were on in BIOS before, I still had not changed the settings in the MSI command center to overclock. So far no more BSODs and CPU seems to be running slightly cooler. Weird though, because my CPU frequency ratios and base clock were still on defaults.
Thanks again
Hello schwall26
Thank you for your response, I am glad to know the temperatures have gone down on the system, please keep monitoring the system and let me know if there is an update.
Leonardo C.
Hello schwall26
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
Hello schwall26
Leonardo C.
