16761 Discussions
Is 90 degrees celcius ok for my processor?
LLent
When I play games, my CPU can reach up to 90-94 celsius degrees. The game doesn't lag, it runs smoothly, but should I be worried about such heat? My CPU is i5-4690 @ 3.50 GHz
SSean
I think your CPU is too hot and you should consider undervolting it in the BIOS (search for a tutorial on how to do that) or replace the thermal paste or replace the heatsink. Also check that your case has adequate ventilation (including checking that fans haven't stopped).
LMert1
Yes, you should be worried because the temperature is higher that what the CPU is designed for.
The maximum case temperature of 72.72°C is the maximum temperature allowed at the processor Integrated Heat Spreader (IHS).
See: http://ark.intel.com/products/80810/Intel-Core-i5-4690-Processor-6M-Cache-up-to-3_90-GHz Intel® Core™ i5-4690 Processor (6M Cache, up to 3.90 GHz) Product Specifications
Either the CPU is over clocked (and should be set back to default) or the CPU fan/heatsink should be cleaned or replaced.
Leon Merts
