- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
So I have the question about intel core i3-3270U 1.8ghz. At idle temperature of cpu is 50-60 degrees of Celsius. but if i watch film online or play a game this is about 70-80. This is normal?. Sorry for my bad english.
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi almostlow, I was not able to find this processor model in http://ark.intel.com/ http://ark.intel.com/ but I believe it is a mobile Intel® processor. You may want to verify the processor model or run the http://www.intel.com/support/processors/sb/CS-031726.htm Intel® Processor Diagnostic Tool.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I`m sorry for wasting time. This is: http://ark.intel.com/products/65697/Intel-Core-i3-3217U-Processor-3M-Cache-1_80-GHz ARK | Intel® Core™ i3-3217U Processor (3M Cache, 1.80 GHz)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Thank you. Now we can find the Tjunction value from the link above.
Tjunction is a value that was established as a point of reference in order to understand what could be expected as per normal processor temperature.
Any temperature value below Tjunction is expected value during normal usage of the processor. If the processor temperature exceeds 130 °C, it will send a signal to the motherboard to shut down to prevent mayor damages and most likely it will not be possible to turn the computer back in until it cools down. The processor temperature depends on different factors: fan speed control (BIOS), cooling solution and chassis type.
The temperature readings you are reporting are within the normal range. However, it is necessary to bear in mind that after some time the cooling solution inside your computer may require maintenance since dust may accumulate over time and thermal paste may need to be replaced. Therefore some recommended steps may include in the event that the temperature values are way higher than what they used to be when you first obtained your computer:
- Obtain a correct temperature reading from a trusted software tool, ideally provided by the system manufacturer.
- Check the fan vents are not obstructed.
- Contact your system manufacturer for related BIOS updates.
- Consult your system manufacturer or computer shop for maintenance.
More information is available in the Datasheet, Vol 1, page 69.
https://www-ssl.intel.com/content/www/us/en/processors/core/3rd-gen-core-family-mobile-vol-1-datasheet.html https://www-ssl.intel.com/content/www/us/en/processors/core/3rd-gen-core-family-mobile-vol-1-datasheet.html
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
