Is it possible to find out if a CPU supports IA32_TEMPERATURE_TARGET?
I don't want to check against every possible CPU if it is in the List of the Supported CPUs i know.
Or if there is no direct way, is there a complete List of CPUs which support the IA32_TEMPERATURE_TARGET?
連結已複製
Please check the following document. The information can be found in Appendix B of the Software Programmers Guide, section 35.
https://www-ssl.intel.com/content/dam/www/public/us/en/documents/manuals/64-ia-32-architectures-software-developer-vol-3c-part-3-manual.pdf https://www-ssl.intel.com/content/dam/www/public/us/en/documents/manuals/64-ia-32-architectures-software-developer-vol-3c-part-3-manual.pdf
All generations of Core i3, i5, i7 support it.Processors based on the Silvermont architecture also support it. That would mean Baytrail, Avoton and Rangely processors.
thanks for the Replay.
I have this Document already and i also found this Information but maybe i was not clear enough.
I look for a nice and elegant Solution to check via C or assembly that a CPU supports IA32_TEMPERATURE_TARGET or not.
Like a feature bit for it or something like that. I was not able to find anything like this in all the Documents i downloaded.
Im also fine with the list i have, i expanded it after reading some bits in vol-3c again, but another solution would be nice.
Also my experience with Intel CPUs is rather limited, i'm more or less a beginner with Intel Architecture.
Well, the point is, i like to do it right but my current Solution "check the current model number against the list of supported ones"
looks rather stupid. Indeed i could shorten the list in some way or check against another list with different criteria but i like to
eliminate the list.
I know that the character of those MSRs is that they are only available on some Models but maybe there is something is missed
Apfel, for this kind of information I would recommend you to access the Intel Developer Zone at the following link https://software.intel.com/en-us https://software.intel.com/en-us
