16841 Discussions
Is the LANconf tool available for linux?
GDura6
Wanner_G_Intel
Hello GDura6,
Thank you for submitting your question on this Intel® Community.
To better assist you, please provide us with the following information:
  • Model number of your Intel® Product.
Wanner G.
GDura6
​I'm using a COM E Type 7 Xeon D 1559 based SBC from Adlink, Express-BD7. I've designed a custom carrier card for the Express-BD7 that has Inphi's CS4223E 10G PHY interfacing to the Express-BD7's KR interface. The SBC's OS is Linux, therefore inquiring if the LANconf SW utility is available in Linux to enable me to configure the Inphi CS4223E device?
Wanner_G_Intel
Hello GDura6,
Thank you for your response.
Please allow us to look into this inquiry. We will update this thread soon.
Wanner G.
Emeth_O_Intel
Hello GDura6,
Thank you for your time.
I was reviewing your thread and I was doing some research and I found that this unit has an embedded "Intel® MAC/PHY: Intel® Ethernet Connection i210-LM " according to the datasheet of the following website: https://www.adlinktech.com/Products/Computer_on_Modules/COMExpressType7/Express-BD7?lang=en
Nevertheless, you mentioned that recently you have added a different Ethernet Card which is the "Inphi's CS4223E 10G PHY".
Are you planning use both interfaces as the same time or which specific configuration are you trying to accomplish?
I would like to know more information of the configuration in order to provide you the most accurate recommendation.
Emeth O.
Intel® Server Specialist.
GDura6
Yes, the interfaces will be used concurrently.
I've designed a custom carrier board that the Adlink Express-BD7 plugs into. On my custom carrier board I have Inphi's CS4223E interfacing to the Express-BD7 KR ports. Attached is a Technical Note from Inphi describing the sub-system (figure 1): in this scenario the processor is on the Express-BD7 and remaining components on my custom carrier card. Note the list of Intel Deliverables starting on page 1. 1c makes mention of the LANconf tool which is my support inquiry.
Emeth_O_Intel
In this scenario, if you are looking for a technical help regarding the Intel LANconf tool, please check the following information:
For Technical Support:
Contact your Intel FAE
Notes
  • If you have any issues with collateral links, please contact your Intel Field Representative.
  • If you do not know your Intel field representative, please contact DesignInTools@intel.com
Please let me know if you have more questions, and I will be more than happy to assist you.
Emeth O.
