16792 Discussions
Issue Running IPDT Installer
KAziz
So I wanted to run MC but I kept getting errors. A did some searching and most people said I should try to update my drivers. I did so and I kept getting told to update my display drivers. I tried to run IPDT Installer and got this error log:
[19E4:2108][2020-06-02T16:55:13]i001: Burn v3.11.1.2318, Windows v10.0 (Build 19041: Service Pack 0), path: C:\Users\Khosr\AppData\Local\Temp\{6EB68498-FC37-4567-9EF2-D7FC5B478C3F}\.cr\IPDT_Installer_4.1.4.36_32bit.exe
[19E4:2108][2020-06-02T16:55:13]i009: Command Line: '-burn.clean.room=C:\Users\Khosr\Downloads\IPDT_Installer_4.1.4.36_32bit.exe -burn.filehandle.attached=580 -burn.filehandle.self=584'
[19E4:2108][2020-06-02T16:55:13]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Khosr\Downloads\IPDT_Installer_4.1.4.36_32bit.exe'
[19E4:2108][2020-06-02T16:55:13]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Khosr\Downloads\'
[19E4:2108][2020-06-02T16:55:13]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Khosr\AppData\Local\Temp\Intel_Processor_Diagnostic_Tool_20200602165513.log'
[19E4:2108][2020-06-02T16:55:13]i000: Setting string variable 'WixBundleName' to value 'Intel Processor Diagnostic Tool'
[19E4:2108][2020-06-02T16:55:13]i000: Unsetting variable 'WixBundleManufacturer'
[19E4:06B4][2020-06-02T16:55:13]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[19E4:06B4][2020-06-02T16:55:13]i000: Setting version variable 'WixBundleFileVersion' to value '4.1.4.36'
[19E4:2108][2020-06-02T16:55:13]i100: Detect begin, 2 packages
[19E4:2108][2020-06-02T16:55:13]i000: Setting string variable 'NETFRAMEWORK45' to value '528372'
[19E4:2108][2020-06-02T16:55:13]i052: Condition 'NETFRAMEWORK45 >= 378675' evaluates to true.
[19E4:2108][2020-06-02T16:55:13]i101: Detected package: NetFx452Web, state: Present, cached: None
[19E4:2108][2020-06-02T16:55:13]i101: Detected package: IPDT32bit, state: Absent, cached: None
[19E4:2108][2020-06-02T16:55:13]i052: Condition '(NOT VersionNT64 AND ((VersionNT>=v6.2) OR (VersionNT>=v6.1 AND ServicePackLevel>=1)))' evaluates to false.
[19E4:2108][2020-06-02T16:55:13]e000: The Operating System is not adequate for installation of Intel Processor Diagnostic Tool.
[19E4:2108][2020-06-02T16:55:13]e000: Error 0x81f40001: Bundle condition evaluated to false: (NOT VersionNT64 AND ((VersionNT>=v6.2) OR (VersionNT>=v6.1 AND ServicePackLevel>=1)))
[19E4:2108][2020-06-02T16:55:13]i199: Detect complete, result: 0x0
Not sure what that means but I can't seem be able to run it.
AlHill
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
W10 2004, W10 May 2020, W10 20H1, W10 19041 - A rose, by any other name, still smells.
KAziz
posted a file.
Sebastian_M_Intel
Hello KAziz,
Thank you for posting on the Intel® communities.
  • Are you having problems installing the latest Intel® graphics driver? Or, do you have problems to install the Intel® Processor Diagnostic Tool (IPDT)? Please clarify this.
  • For any of the problems that you have, can you provide a screenshot of the error message that you are getting when doing it?
  • Were you able to have your system working as expected before? If yes, did you make any changes before this started?
Sebastian M.
Intel Customer Support Technician.
Sebastian_M_Intel
Hello KAziz,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M.
Sebastian_M_Intel
Hello KAziz,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please feel free to post a new question.
Sebastian M.
Miks
Hello.
I've had some issues with downloading the IDPT when I tried running the file it said: "The operating system is not adequate for intallation of intel processor diagnostic tool.''
I attached an SSU text file.
