16794 Discussions
Issue with Adaptive OC
MElbs
I tried to set up an adaptive profile with those settings to my i7 8700K CPU on a motherboard ASUS maximus Hero X
Sync all cores 48
SVID Enabled
SVID behavior : best case scenario
addtional turbo mode core : 1.265
offset -
IA DC Loadline : 0.01
IA AC Loadline : 0.01
But the vcore for what i see in HW monitor goes from 1.20 to 1.28 . Shouldn't it goes lower on idle?
I have no idea where is the issue...
Thanks for your help.
Hello Asryan
Thank you for posting in the Intel® community.
Allow me to share with you some information about overlooking (https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html https://www.intel.com/content/www/us/en/gaming/overclocking-intel-processors.html)
Please bear in mind that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of system and components for additional details.
Hope this helps.
Leonardo C.
MElbs
I'm fully aware of it and I had no issues with any OC untill now But I just don't get why my adaptive one won't work as I want
Hello Asryan
Thank you for the information.
At this point, my only recordation is to load the default BIOS settings and test the processor behavior/performance and go from there
You could review the processor behavior with the Intel® XTU.
https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU- https://downloadcenter.intel.com/download/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-
Leonardo C.
Hello Asryan
I was checking your case and I would like to share with you that in case you are planning to use overclocking the Intel® Processor we recommend the use of the Intel® performance tuning protection plan (https://click.intel.com/tuningplan/ https://click.intel.com/tuningplan/).
Leonardo C.
