16784 Discussions
Jupyter hub crashes when running multiprocessing (6cores) script
asome2
Hi, I'm running a very simple script,
however the entire system crashes after 2-3 minutes of running.
import os
import json
import pandas
import sys
import multiprocessing as mp
def jsons2df(path):
json_list=[]
file_list = os.scandir(path)
counter=0
error_counter=0
for j_file in file_list:
counter+=1
if counter%10000==0:
print(counter)
# with open(os.path.join(path,j_file),"r") as j:
with open(j_file.path,"r") as j:
try:
data = json.load(j)
except:
print("ERROR: ",j_file)
error_counter+=1
if error_counter>1000:
break
else:
continue
json_list.append(data)
try:
json_df= pandas.DataFrame(json_list)
b=json_df["url"].apply(lambda x: x.split("/")[2])
json_df['domain']=b
return json_df
except:
return json_list
def get_and_extract(number):
print("starting: ",number)
if not os.path.isfile("%s.tar"%(number)):
if not os.path.isdir("%s"%(number)):
if not os.path.isfile("./pickles/wiki_%s.pickle"%(number)):
print("downloading")
url=" http://data.dws.informatik.uni-mannheim.de/webtables/2015-07/englishCorpus/compressed/%s.tar.gz"%(number)
os.system("wget %s"%(url))
print("extracting gz # 1")
os.system("tar -xzf %s.tar.gz >/dev/null"%(number))
os.system("rm -rf %s.tar.gz"%(number))
if os.path.isfile("%s.tar"%(number)):
print("extracting tar # 2")
os.system("tar --skip-old-files -xf %s.tar >/dev/null"%(number))
os.system("rm -rf %s.tar"%(number))
if number.startswith("0"):
number=number[1:]
path="./%s"%(number)
df =jsons2df(path)
print("pickling:")
df.to_pickle("./pickles/df_%s.pickle"%(number))
b=df[df.domain.str.contains("en.wikipedia.org")]
b=b[~b.url.str.contains('Special:Book')]
b.to_pickle("./pickles/wiki_%s.pickle"%(number))
if os.path.isdir("%s"%(number)):
print("Deleting:")
os.system("rsync -r --delete emptydir/ %s/"%(number))
os.system("rmdir %s"%(number))
print("Done: ",number)
# get_and_extract(number)
def main(number1,number2):
# pool=mp.Pool(CORES)
pool = mp.Pool(6)
print(number1,number2)
print("Looping:")
for i in range(int(number1),int(number2)+1):
print(i)
x =str(i)
y=0
x =str(i)
y=0
a=pool.apply_async(get_and_extract,(x,))
# a=pool.apply_async(get_and_extract,(x,))
# print(a)
pool.close()
if __name__ == '__main__':
number=sys.argv[1]
number2=sys.argv[2]
main(number,number2)
Hi Amit,
We tried out the script from our end and the results are attached.
I would suggest you try out the following:
1. Are you using a virtual environment to run the file. If not, please give it a try.
2. Is the notebook crashing because of large numbers being passed to your main function. i.e. main(number1,number2)? Kindly verify that.
Please confirm on the above options and if the issue still persists, kindly send a screenshot of the error message(if any).
Thanks & Regards,
Sandhiya
asome2
1. Yes I am using a virtual environment and it still crashes.
2. Small numbers are passed and the crash is immediate , i.e. main(32,35)
Sadly,
Issue is not resolved.
asome2
No error, just that my jupyter instance restrats.
Hi Amit,
Unavailability of free space can cause Jupyter notebook to crash without showing an error. Kindly check your usage and let us know if your issue is resolved.
Thanks & Regards,
Sandhiya
asome2
I checked and the issued is not resolved
Hi Amit,
Hope the cleaned account is working fine. Do get back incase you are still facing the issue.
Thanks & Regards,
Sandhiya
Hi Amit,
We did not hear back from you and hence we are closing this case. Do open a new thread incase you face any issues.
Thanks & Regards,
Sandhiya
