Low CPU Frequency
sauka
I have Dell Latitude 5500, Win11, CPU i7-8665U. From time to time CPU is going to very low frequency (0.6-0.7GHz, when nominal is 1.91GHz. And it happens randomly, meaning if the load is high (being plugged in). As a consequence, everything is lagging heavily. I've mentioned, that if I set power saving mode on and then off quickly, it help get back to high frequency.
Is it a cpu issue or am I missing smth in setup?
ACarmona_Intel
Hello sauka,
May I know when the issue started? And also, what steps have you taken to troubleshoot the issue? This will help me to prevent providing you with the same troubleshooting steps.
Furthermore, please generate an SSU report to help me further analyze your system specifications. To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
By the way, since this is an OEM (branded laptop) original equipment manufacturer device, please take into consideration that our support may be limited since we are not familiar with the technology, settings, customisations, custom drivers, and features that the OEM has designed and installed on your system; nevertheless, I will do my best to assist you with your concern.
Carmona A.
ACarmona_Intel
Hello sauka,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
Hello sauka,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Carmona A.
ACarmona_Intel
Hello sauka,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
