16800 Discussions
My i7 8700 running a bit hot
GLian8
Hi i upgraded my PC 9 months ago but now my proceccor is just running way to hot 90+ from just playing league of legends i even bought a new cooling system but still way too high temps
AlHill
Make sure you have the proper ventilation and cooling.
As long as you are under 100C, you are ok.
https://ark.intel.com/content/www/us/en/ark/products/126686/intel-core-i7-8700-processor-12m-cache-up-to-4-60-ghz.html
Doc
GLian8
well i mean i dont know if it goes over cause when i use the hwmonitor it just jumps from 90 to 100 and i assume that 100 is the max of hwmonitor when i fist got it 9 months ago on idle it was hitting at worse 35 degrees celsius now on idle it has 65 deggrees i am pretty sure somethin isnt right
GLian8
Ventilation and cooling are brand new as well. I have a brand new corsair h60 and 3 ventilation funs
n_scott_pearson
How is the H60 controlled? Using a fan speed controller on the board? If this is the case, have you verified that the fan speed control programming makes sense? This is typically managed in the BIOS.
Hope this helps,
