16798 Discussions
No longer able to scan default VF curves
DMC360
Whenever I click the Scan Default VF Curve button the process apprears to start, but the curve doesn't appear in the graph window. When the process appears to finish, a message is displayed above the graph window that states "Could not set Processor Core Ratios back to the state before VF Curve Scan. Use Manual Tuning to set them back." When I check the core ratios on the Advanced Tuning tab they are all set to the listed default value. Also, I have the default profile loaded so it is unclear why it would need to set the core ratios to any other value. Everything was working as expected until August or September. Please advise on how to resolve this issue.
DeividA_Intel
Hello DMC360,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i9-12900KF Processor.
1. Is this issue recent? Did it work before?
2. Just to confirm, when you mentioned "I have the default profile loaded", do you mean that the BIOS is on default settings?
3. Have you tried to reinstall the tool?
4. Have you updated the BIOS version? If you have not, I recommend you check with Asus since you may need instructions to install it safely.
Also, as a friendly reminder (even though you may not doing it) bear in mind that altering clock frequency or voltage may damage or reduce the useful life of the processor and other system components, and may reduce system stability and performance. Product warranties may not apply if the processor is operated beyond its specifications. Check with the manufacturers of the system and components for additional details.
Deivid A.
DeividA_Intel
Hello DMC360,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello DMC360,
I reviewed your post, please let me know if the issue was resolved, if not, do not hesitate, just reply back with the following information:
Deivid A.
