公告
P4 mobile on
员工
1,517 次查看
hello
is it possible to use P4 sl7nb In Desktop PCs?, in wich case?
si qq'un a la reponse en français ça serait encore mieux
many thanks
processeur P4 3,2 ghz socket 478
S-Spec number/sspec/SL/SL7NB.html SL7NBProcessor TypeMobile Pentium 4Processor number538Part number/CPUs/Pentium_4/Intel-Mobile Pentium 4 538 3.2 GHz - RK80546HE0881M.html RK80546HE0881MProcessor speed (MHz)3200Bus speed (MHz)533L2 cache size (KB)1024Package type478-pin FC-mPGA4Socket type/Sockets/Socket 478 (mPGA478B).html Socket 478 (mPGA478B)Manufacturing technology (micron)0.09Core SteppingE0CPUID0F41hCase temperature (°C)75Core voltage (V)1.25 - 1.4Processor corePrescottFeaturesEnhanced SpeedStep
Hyper-Threading
TM2
1 回复
Adolfo_S_Intel2
673 次查看
You need to contact the desktop motherboard manufacturer so they can tell you which specific processors are fully compatible with their motherboards.
Keep in mind that the compatibility between the processor and the motherboard is determined by the motherboard manufacturer.
0 项奖励
回复
