16975 Discussions
Pentium N3700 memory bandwidth
I tested my pc with different software to measure memory bandwidth (MAXXMEMII, GeekBench), and result is around 4 GB/s
My laptop have 4GB of DDR3 1600, following information on the wiki bandwidth should be around 12 GB/s
What is the problem with and how i can solve it?
AKian
This is normal due to the product design goals, product segmentation and product price point of Atom based processors.
Just use your PC normally for what it was designed for and don't keep thinking about benchmark metrics.
It can perform all non-gaming tasks that you throw at it, just less fluidly than Core processors.
So why they put ddr 3 modules in laptop instead ddr 2 (8 GB/s) or even ddr 1 (4 GB/s) ?
Is it really important to support DDR3 in pentium n3700 if you can't use it even on a half?
AKian
RAM is cheapest for variants that is in high production volumes. DDR 2 or DDR1 one RAM is obsolete and no longer in high volume production, making them much more expensive.
DDR3 is supported because of the ubiquity of supply globally.
Based on the processor specifications you should be able to get 12GB/s.
http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/pentium-celeron-n-series-datasheet-vol-1.pdf http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/pentium-celeron-n-series-datasheet-vol-1.pdf
Page 22
What I can think is that your system manufacturer has limitted this specification, that also depends on the memory RAM that your system has installed, I would suggest to contact your system manufacturer in order to see if they have more information about it as they are more familiar with your system and how all the components interact with each other.
By any chance, do you have the RAM part number that you have installed on your computer?
I just want to check more information about it.
Ivan
Thanks for the answer!
My ddr3 module is: adata adds1600w4g11-b
My laptop is: clevo w940lu
I hope it can be fixed somehow through firmware update if there is no hardware limitations.
I was checking with your system model through the website but I did not find anything that it tells me anything about the issue you have, at this point I strongly recommend contacting your system manufacturer to get better information about it or to see if there is any limition about it.
http://clevo.com/clevo_contact.asp?lang=en 藍天Clevo
Ivan
AKian
In reference to the review on this page for the Pentium N3700 http://www.techspot.com/review/1014-intel-celeron-n3050-pentium-n3700/page2.html Intel 'Braswell' Celeron N3050 & Pentium N3700 Review > System Specs & Memory Bandwidth - TechSpot
The Asrock N3700-ITX which uses the Pentium N3700 attained 9.6 GB/s of memory bandwidth when used with dual channel (2 sticks) of DDR3-1600 RAM.
If your Clevo laptop is running on a single channel (1 stick) of DDR3-1600 RAM, then a bandwidth of 4.8 GB/s is expected.
There is no problem with your laptop.
If you are looking for full memory bandwidth, a Core architecture processor would be a better choice.
So if i'll buy second ram module it will work faster (if it's supporst dualchannel)?
AKian
According to the page for your laptop W940LU http://www.clevo.com/clevo_prodetail.asp?id=799&lang=en http://www.clevo.com/clevo_prodetail.asp?id=799&lang=en
Your laptop supports dual channel DDR3 RAM. You can get one more stick of RAM that is identical to your existing adata adds1600w4g11-b.
With dual channel RAM, you should get about 9.6 GB/s. The performance boost from this upgrade is marginal (small) and may NOT be felt in your daily usage.
You can get a much bigger performance boost from upgrading your HDD to an SSD such a Samsung 750 EVO. http://www.samsung.com/sg/consumer/memory-storage/memory-storage/ssd/MZ-750250BW http://www.samsung.com/sg/consumer/memory-storage/memory-storage/ssd/MZ-750250BW
Thank you alvinkiang for your contribution on this thread, this information you have kindly provided is very valuable and very much appreciated.
Best wishes,
Ivan
