17499 Discussions
Power plan and Core usage
SureshRU
Hi Everyone,
Hope you are doing  great.
I will like to check whether is there any documents or information on the following:
Different Power Plans and Core Usage:
  • Battery Saver Mode (for Intel i7 13th Gen processor):
    • How many cores are active in this state  and how many are inactive to maximize battery savings?
  • Balanced Mode (for the same processor):
    • How many cores are active to maintain this state?
    • When handling heavy workloads, how many cores are allocated to effectively balance the load and optimize performance?
  • Best Performance Mode (for the same processor):
    • since the term best performance , believe all core must be in use. but it will be good if there is some article or breakdown
VARADHARAJAN
Valued Contributor II
SureshRU
Hi Varadharajan,
thank you for the reply, however i was not able to locate the correct technical document via the link provided.
do you have the exact link for that article ?
SureshRU
Hi Varadharajan,
you may ignore my previous comment.
found it.
