16766 Discussions
Problem with XPS8700 With CORE i5, Help!
LLuis3
Hi I have a serious problem. I have a XPS8700 with CORE i5, the problem is that a month ago I will maintain my computer, but I happened not to leave the CPU fan backwards. Then yesterday of nowhere the computer is off I go and I realized the error.
The processor step little over a month with the fan backwards. It is possible that I found damaged the processor?
Thank you for your answer in advance.
LLuis3
Ya pude verificar el problema y con la ayuda del auto diagnostico de la fuente que trae el XPS8700, pude identificar que la Board es la que se daño y el procesador CORE i5 esta bien.
Gracias a mi mismo por auto responderme y ayudarme
Ya que muchos vieron la publicación pero nadie pudo dar una opinión que ayudara.
LLuis3
Hello Luis
We are glad to hear that there is no problem with the processor and that you were able to identify the problem.
Any questions, please do not hesitate in contact us again.
Alberto
Hello Luis
Is the fan working fine as well?
Alberto
