Hola, quiero saber que velocidad de memoria ram soporta este porcesador, quiero comprar memoria nueva y no se de que velocidad soporta?
Gracias
It supports DDR3 memory. But, in their wisdom, intel has deleted specifics about the memory. Best to check what your motherboard or device supports.
If you have a currently running system, you can run cpu-z to determine the current memory speed.
[AI is the same as snake-oil]
