Ankündigungen
Prosessor
GElli1
Einsteiger
2.913Aufrufe
Hi
I Just wonder if the memory controller in the I76950x is mutch
diffrent in an I7 5960x?????
6 Antworten
MUday
Einsteiger
1.765Aufrufe
I have been using a i5 Intel processor with out any issues so far, but now i am having BSOD Errors.
I am also using a Intel Motherboard and Nvidia Video Card.
Not sure what is causing the BSOD.
http://www.dentalapps.in/ Meena
Mitarbeiter
1.765Aufrufe
Djultra, in regards to your question, yes it is different, and both processors are different generation; here you can get the comparison of both: http://ark.intel.com/compare/82930,94456 http://ark.intel.com/compare/82930,94456
Meenauc, for your issue I will need more information, What is the error message you are getting?
Could you please attach the result of the Intel® System Support Utility?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Hellen.
GElli1
Einsteiger
1.765Aufrufe
Hi
What i mean to ask if is the memory controller in the I7 6950x Prosessor
support this memory CMD64GX4M8A2400C14 ?
Mitarbeiter
1.765Aufrufe
GElli1
Einsteiger
1.765Aufrufe
Ha
I knew it Asus say its the memory controller ho doesnt find all of my ram size, but i suspected
that it was they bios ho does it!!
Thanks Wery Mutch!!!!
Mitarbeiter
1.765Aufrufe
Hi Djultra,
Thanks for the update, if there is anything else you need, do not hesitate to contact us back.
Hellen.
Antworten
